AR Brakes Locked Up
MB in NE
02-25-2005 21:10:25
Here is another one for the prize I picked up. The brakes are froze-up. Now, do I remove the tires and fenders and pull the things, or is there another way? Won"t Budge
bent
02-27-2005 07:23:10
 Re: AR Brakes Locked Up in reply to MB in NE, 02-25-2005 21:10:25
MB, there is a round cover that can be removed from the rest of the fender with 4 small cap screws. You should be able to get a wrench or socket on to the nut that holds the drum on and remove the drum. You will be able to see inside and figure out what is stuck. If you take the tires off (6 nuts), things will be a lot easier. If this is all the mechanical work you are going to do, you can also take the wheel centre off (6 bolts) and slide the whole brake assembly right off the tractor. Just make sure you move each bolt to the bottom of the axle housing before you tap it out. Don't beat on the outboard bearing retainer.
Bent
MB in NE
03-01-2005 21:34:56
 Re: AR Brakes Locked Up in reply to bent, 02-27-2005 07:23:10
Thank you for the iformation Bent. If i don"t go to MN this weekend I"ll try and tackle the problem. Martin Benton
bent
03-02-2005 07:36:52
 Re: AR Brakes Locked Up in reply to MB in NE, 03-01-2005 21:34:56
MB, the job is more awkward than difficult. I have some pictures and more information about brake rebuilt. As time goes by, I find that these tractors were designed to be dismantled to service major components, but the good part is that you probably won't ever need to worry about brakes again.
Bent
jdabg
02-26-2005 19:18:50
Mine were locked up also, your can pull the brake assemble by the 3 bolts holding it to the tansmission housing. You can move the tractor then just be careful no brakes. The IT manual I have explaines better than I can how to take them appart. Mine were full of dirt and rust but was able to get them working again.
MB in NE
02-26-2005 20:50:06
 Re: AR Brakes Locked Up in reply to jdabg, 02-26-2005 19:18:50
Thanks for the information jdabg.
