Carb on JD G (DLTX108UA)
JD Texan
02-25-2005 17:48:30
The carb on my "G" does not have the threaded brass drill plugs. The passages are pluged with brass plugs but they are not threaded. Can these plugs be drilled out and holes tapped to fit regular threaded drill plugs (10-32,12-32& 14-28)or do they make replacement drive in plugs?
I believe the DLTX108UA is a aftermarket replacement carb.
Thanks for any suggestions,
Bruce :)
Duane Larson
02-25-2005 21:52:52
 Re: Carb on JD G (DLTX108UA) in reply to JD Texan, 02-25-2005 17:48:30
Bruce,
Your carburetor is one of three "universal" carburetors put out by Marvel Schebler in the '70's to replace the original 1 and 2 barrel carbs. The brass plugs can be drilled out and the passages tapped for the "usual" brass plugs used on the DLTX51. The plugs usually come out fairly easily - I drill and tap for a 4-40 screw and pull them.
JD Texan
02-25-2005 22:55:49
 Thanks in reply to Duane Larson, 02-25-2005 21:52:52
Thanks Duane for the good info. I will put it to good use.
Bruce
