BRINGING BACK TO LIFE A 730 DIESEL
Scotty
02-25-2005 15:57:41
I AM WORKING ON MY 730D PROJECT AND THINGS ARE GETTING BETTER AS FAR AS GETTING THE MOTOR RUNNING. TO START WITH THE MOTOR WAS STUCK BUT NOT TO BAD , I WAS ABLE TO ROTATE THE ENGINE AFTER ABOUT A COUPLE OF WEEKS OF SPRAYING PB BLASTER DOWN THE EXHAUST PORT OF THE HEAD, AFTER REMOVING THE EXHAUST MAINFOLD.THEN WITH A NICE PRY BAR GRABED A TOOTH ON THE FLYWHEEL AND WEDGED THE BAR AGAINST THE STARTER AND JUST KEPT WORKING THE FLYWHEEL BACK AND FORTH UNTIL IT FINNALY WOULD SPIN ALL THE WAY AROUND BUT IT STILL HAD A TIGHT SPOT IN IT WHICH TURNED OUT TO BE TWO STUCK VALUES. GOT ONE LOOSE WITH THE PB BLASTER , A HAMMER AND A PRY BAR BUT THE OTHER VALUE WHICH IS A EXHAUST VALUE WON'T FREE ALL THE WAY UP. I CAN ROTATE THE CRANK UNTIL THE PISTON IS ALL THE WAY DOWN AND TAP THE VALUE IN BUT I HAVE TO ROTATE THE CRANK TO USE THE PISTON TO PUSH THE VALUE BACK OUT. WHEN THE VALUE IS ALL THE WAY SHUT I CAN SPIN THE VALUE AND IT FEELS LIKE IT IS SEATING GOOD TO THE SEAT BUT WHEN I TAP IT IN ABOUT A 1/4 INCH IT GETS TIGHT , SO BAD THAT I HAVE TO USE THE PISTON TO PUSH IT BACK OUT. SHOULD I KEEP WORKING WITH THE BLASTER AND A HAMMER OR DO I HAVE A BENT VALUE ? THANKS FOR YOUR TIME AND HELP
SCOTTY
Dean
02-26-2005 09:46:15
 Re: BRINGING BACK TO LIFE A 730 DIESEL in reply to Scotty , 02-25-2005 15:57:41
I agree with Mike. I do not believe you have much to loose by working it around at this point. Be patient and take your time.
I like these old tractors, especially 730s and I hope you can bring her back to life. You do have a project on your hands though.
Good luck!
Dean
Mike M
02-25-2005 18:49:16
At this point you don't have much to loose. I'd keep soaking it and trying to free it up then hope you have enough compression to fire it up so you can test the rest of the tractor then fix it at a later date if you want.
msb
02-25-2005 18:35:04
I have seen diesel engines that have set for a long time stick because the oil settled out and left carbon deposits on about everything.I once started a Cat 955 only to have the oil pump drive shaft immediately shear the key in the gear.The carbon had stuck that drive shaft so tight you would not have believed it.If you suceed in getting the tractor started, watch the oil pressure like a hawk and change the oil shortly there after.
If it were me, I would be tempted to dismantle the engine first before I attempted to crank her up.Might save a lot of new damage.
Scotty
02-26-2005 12:12:04
 Re: BRINGING BACK TO LIFE A 730 DIESEL in reply to msb, 02-25-2005 18:35:04
Thanks, I can see a little black on the stem of the value, it almost looks like ink. Maybe the discoloring is carbon. I'm going to keep hacking at it until I've had enough, then I'll pull the head. I was hoping to get it running and use it alittle while and fix things as I see them, alittle at a time... Thanks for your help...Scotty
ham
02-25-2005 17:58:02
Scotty, what is your goal? Do you just want to get it running so you can check the clutch and transmission and steering to see what else it needs? Since the pistons were stuck then the rings and cylinder walls are going to be rusted and rough. Thats probably going to show up quickly as white smoke, and slobbering out the exhaust due to incomplete combustion. The valve you are fighting may or may not be bent, could just be a bad area on the stem that is binding. Of course you won't be able to try and start it if you can get the valve spring to return it. If it is bent the end of the valve stem should wobble as you spin it. If you have to pull the head to fix the valve then you might as well go ahead and fix the rest of the engine up in my opinion. All depends on what you want. We did a 50 once that had been stuck. We got it going, but after about a year we weren't happy with how it ran so we ended up doing the engine. The choice is yours, good luck with it.
Scotty
02-26-2005 05:28:00
 Re: BRINGING BACK TO LIFE A 730 DIESEL in reply to ham, 02-25-2005 17:58:02
Yeah, I would like to get it runnig to see what is going on with the rest of the tractor too.I think it will run if I can get the one value to return. I'm going to roll the value stem around like you said and look a little closer for a wobble. Thanks for your help.....Scotty
buickanddeere
02-25-2005 18:05:52
I agree, those valves are bent form turning the engine before checking if the valve train was free. That tractor may have been parked for a reason like it was going to cost more to repair than what it was worth. What condition is the rest of the tractor? Tires, fenders, instruments, electrical, pto shields, sheet metal, grill, three point hitch. Check the flywheel for being loose in the past, stretched bolts or having been welded to the crank. That cylinder head will need four valve guids, four valves, maybe springs, likely a couple of pushrods, four new seats, hot tanking, crack testing and machining. Grinding old valves and seats in a diesel just makes them misorable to start when cold.
Scotty
02-26-2005 05:17:18
 Re: BRINGING BACK TO LIFE A 730 DIESEL in reply to buickanddeere, 02-25-2005 18:05:52
Thanks. The old guy I got the tractor from says the tractor ran good the last time he used it but that's been about 20 years ago. The head, looking from the outside looks slick, no rust or trash laying around any where inside the value cover or head. It looks really clean.I can't move the value stems side to side any in the guides so the guides aren't worn to bad, springs look good But I do have 1 bent pushrod. when I remove the springs and roll the values around the seats feel slick. With all the values closed and the rocker arms off when I roll the motor around you can hear the compression so I know it's making alittle compression. I think i'm going to keep twisting and working with the one value a little longer and see what happens. Thanks for your help,....Scotty
Metal Master
03-02-2005 00:22:08
 Re: BRINGING BACK TO LIFE A 730 DIESEL in reply to Scotty , 02-26-2005 05:17:18
Patience helps ... In soaking, give it time. They have stuff just made for freeing engines. We got one old tractor to free up with the soaking ... then gave it a pull start. It would fire as long as we were pulling it. The way to do your problem, if you are in for punishment, is to take the engine apart, so that you don't have to guess.
