48 D starter lever ,Old or Clooney
Paul.D.Canada
02-17-2004 15:33:05
It appears that my "D" does not have this starter lever on the side of the battery tray as shown in the operators manual!I looked today and it seems to be a spring return knob on the centre of the dash between the choke and the light switch.The wires appear to go to the solenoid.(I need to take the hood off for a better look). Is this possilbe or was electric start added to this tractor later or?In the operators manual it shows the middle knob as the choke(and extended out to the lid of the battery box) and the end hole empty.On page 51 it shows the set up that I have, but does not explain it.Could someone please enlighten me before I hook the battery up!Oh, before I forget were do you put the oil in! It sounds like a dumb question but I have been through this op. manual 6 times and still can't find it.I have an idea but want to be sure.Also where can you buy spark plugs and what kind do you recomend for this tractor?Thanks in advance Paul.
37D
02-18-2004 05:57:56
 Re: 48 D starter lever ,Old or Clooney in reply to Paul.D.Canada, 02-17-2004 15:33:05
By checking my parts manual,I discovered a serial# break in the starter system. It appears that tractors starting with #188058 were equipped with the lever type starting system, & I did guess right,- the later starters do have a switch rather than a solenoid.
Paul.D.Canada
02-18-2004 14:39:26
 Re: Re: 48 D starter lever ,Old or Clooney in reply to 37D, 02-18-2004 05:57:56
37D, thanks for the info, do you mind if i direct some more questions your way?Thanks Paul.
37D
02-18-2004 05:46:41
Apparently JD built styled "D"s with two different starting systems. Mine is like the other posts, has a pull type switch.However my owners manual shows a "starting lever" to the left of the battery & the choke rod extended to the rear right side of the battery. I actually saw a "D" with the starter lever at an auction at I believe, Colombus NE a couple years ago, but don't remember(or didn't notice) if the choke rod was extended. I'm assuming that if there is a lever, there wouldn't be a solenoid on the starter,but a switch like a lot of other 2cyl JDs,& would be actuated by a rod from the lever to the starter.
John T
02-17-2004 19:56:32
Paul, I dont know the exact year, but my friends late styled D has a pull to start spring return switch on the dash which is wired to the starter solenoid for starting. I have best luck using Autolite plugs one heat range hotter than normally specified, others like other brands better, available at John Deere, NAPA, and tractor stores like Big Blue, Central Tractor, Rural King, Tractor Supply etc etc which should have the application chart listing Chamoion, AC and maybe the Autolite plug numbers.
Good Luck n God Bless ya
John T
old
02-17-2004 18:18:00
Paul on a D theres a lot of people that know a lot more then I do. To tell the truth I have never seen a D, now if its an A, or B I have a good guess. I would have told you the breather tube as Clooney did as far as the oil, but thats about as much as I would know on a D.
Sorry I couldn't help you on this one.
As far as questions on how to get them to run I can help, I've been told I could make anything run, and at times all I have had to do is look at them. True story by the way, done that more the once.
Wayne in MI.
02-17-2004 16:56:11
The center button on the dash is the electric start button. it is spring loaded, so pull and let go when it starts. The oil filler is the crankcase breather on the right side of the engine, release the two large spring clips and remove the top , oil goes in here, 12 qts. You can get plugs from the John Brillman Co phone540-477-4112. Hope this helps
Paul.D.Canada
02-17-2004 18:00:56
 Re: Re: 48 D starter lever ,Old or Clooney in reply to Wayne in MI., 02-17-2004 16:56:11
Thanks this helps alot..... .....Paul.
Clooney
02-17-2004 16:46:43
Paul, I'm not sure what lever you are talking about... I don't have a late D owners manual.. That D uses [or should have] a dash mounted electric starter switch.. Is it possible your manual is referring to a remote fuel 3-way control rod..
~The oil goes in the crankcase breather after you pull the top air stack off of it.
~On the spark plugs? You should be able to get them about anywhere.. I Use Champion in most of my old Deere 2-cylinders but some people seem to have problems with the Champion plugs. It depends on how you are going to use the tractor & the engine condition..
[email protected]
