AR Transmition 4 or 6 Speed
MB in NE
02-23-2005 21:30:42
Ok gents, I resently bought an AR JD witch the serial# indicates is an unstyled 49 model. A self proclaimed JD expert told me that it is not a "49" becouse in "41" JD put only 6 speed transmitions in them. Mine has two forward one reverse, and a high and low. What is your take on this? Thank You.
bent
02-27-2005 07:32:57
 Re: AR Transmition 4 or 6 Speed in reply to MB in NE, 02-23-2005 21:30:42
MB, your serial number indicates that your tractor is a '49, one of the last U/S AR's. I have one of the first Styled AR, also a '49. However, I also have access to look at a '47. I went out on saturday and had a look just to be sure before I posted. There were no 6 speed U/S AR. The 6 speed didn't come out until the styled model. Your shift pattern is correct, you should have 3 slots on the quadrant and another lever to select a different range, effectively making it a 4 speed. There is a lot of "experts", that much we can't control. But what we can control is our reaction to bull-oney. Now you can also put the rest of what this genius says into perspective.
Bent
CMB
02-24-2005 08:19:07
If your "AR" has a serial # above 272000, it would be styled & have a six speed transmission.(Unless it was ordered on steel, then I THINK 5th & 6th gears would have been either blocked off or not there at all.) If the # is below 272000 , it would be unstyled & have a four speed transmossion. The styled "AR"s were untroduced in June of 1949.
bent
02-24-2005 06:27:10
What is the serial number? That shift pattern does not sound right.
Bent
1945 A
02-24-2005 05:48:53
According to the data listed on the Johnnypopper.com site, the early version had 4 speed, the later (after ser.# 26001) had 6 speed transmissions.
MB in NE
02-24-2005 16:55:27
 Re: AR Transmition 4 or 6 Speed in reply to 1945 A, 02-24-2005 05:48:53
The serial # is 270... The shift pattern has 1st. 2nd. high and low, revers in low. Thanks Again
1945 A
02-25-2005 09:19:05
 Re: AR Transmition 4 or 6 Speed in reply to MB in NE, 02-24-2005 16:55:27
Silly question, because I have an "A", so I'm not sure about differences, but, could someone have put a different shifter/top cover on your tractor? In other words, the gears are there, you just can't get to them....
Just a thought, for what it's worth.....
bent
02-25-2005 07:04:14
I am going to go out and look at mine and post back.
Bent
bent
02-25-2005 07:04:00
Bent
