1951 G rod bolt torque
Deerejon
02-23-2005 19:17:01
I'm overhauling a 1951 G with slip in rod bearings and I need to know if I'm using the right torque. My ITT book says for B, G, and H tractors, torque the rod bearing caps at 62.5 lbs. of torque. It says to torque A and D tractors at 100 lbs. of torque. I want to do this right the first time, so is this a miss print in the book or is this right? Thanks for any help you can give me.
Duane Larson
02-23-2005 19:59:37
 Re: 1951 G rod bolt torque in reply to Deerejon, 02-23-2005 19:17:01
Deerejon,
The I&T manual is correct. JD Field Service Bulletin 167 originally gave 75 ft-lbs for the G and B, but FSB 186 revised the values to 62.5 ft-lbs for the B and G, and 100 for the A and D. In all cases, tighten to the value given above, then continue until the cotter pin can be inserted (info also from the FSB).
deerejon
02-23-2005 20:11:23
 Re: 1951 G rod bolt torque in reply to Duane Larson, 02-23-2005 19:59:37
Thanks for the reply Duane, now I can close up the engine compartment and finish the restoration, This is a G high crop and I want done right.
