Early B rear wheel stuck to axle!
Centaur Nut
02-23-2005 19:06:58
The rear axle bearing on my unstyled B has come completely apart, and I've been trying for three days to get the wheel off the axle. I know I have to pull the rear end cover and unfasten & pull the axle to replace the seal. My question is, can I pull the axle out with the wheel still on it, and then worry about getting the axle loose? It has flat spoked steel wheels, and I don't want to beat on them too much! Suggestions, Anyone?
mbptractor
02-23-2005 19:35:02
 Re: Early B rear wheel stuck to axle! in reply to Centaur Nut, 02-23-2005 19:06:58
try putting a GOOD heavy chain around the cast part of the hub and put a 20 ton jack on the end of axle. it works real well.
