3 Point Hydraulic Wood Splitter Hook Up
Willard Engelha
02-23-2005 16:17:06
I have a model 4110 John Deer Tractor an would like to hook up a 3 pointlog splitter to the tractor hydraulic's, so what is the best way to hook it up? any help would be appreciated.
Willard Engelhardt
thurlow
02-23-2005 16:58:42
 Re: 3 Point Hydraulic Wood Splitter Hook Up in reply to Willard Engelhardt, 02-23-2005 16:17:06
Not familiar with your tractor; does it have the capacity (gallons per minute) to run a splitter?. If not, you'll need an external hydraulic pump. When I first built mine.....25 or 30 years ago....I ran a remote control cable from the tractor's hydraulic lever to splitter so it could be operated by one man, if need be. Later added a 2-spool Gresen valve control so I can also operate a hoist to load the blocks. Pressure hose from tractor to valve and return hose to other side of same outlet..... .
