Help!! JD 620 power steering pump.
JR Repair
02-23-2005 15:44:16
I am working on a 620 power steering pump and need to know what seals it between the pump housings. There is no o-ring, and my JD dealers cannot tell me what to use.
Larry in WNY
02-28-2005 09:40:21
 Re: Help!! JD 620 power steering pump. in reply to JR Repair, 02-23-2005 15:44:16
I attended the Waterloo Swap Meet and Service School recently. Gary Uken taught Power Steering Rebuilding and recommends using a very thin coat of HondaBond (available from a Honda dealer) to seal the pump surfaces. Also use 2 shaft seals facing back to back (inside seal towards the oil and the outside seal away from it) on both ends of the shaft. The original seals were double lipped whereas the new ones have a single lip. The dealer may show a spacer used, but this isn't needed.
F-I-T
02-23-2005 16:10:07
I used the thin Permatex one several. Gasket Shellac like Redhead works well, too. Thin, unbroken coats will do fine.
Frank
F-I-T
02-23-2005 16:11:49
 Re: Help!! JD 620 power steering pump. in reply to F-I-T, 02-23-2005 16:10:07
Geeeez. It was supposed to say ON SEVERAL.
Frank
