How can i get the most HP outa a 44 A
Kerr
02-22-2005 18:17:49
i'm wondering how to get the most Hp out of my 44 a without boreing it over or putting on a bigger carb. Someone told me to clean my air cleaner to get a little bit more air to the carb. is this true?
Mike M
02-23-2005 04:52:34
 Re: How can i get the most HP outa a 44 A in reply to Kerr, 02-22-2005 18:17:49
To get the most HP without boreing it out. Pull out the all-fuel pistons and put in a set made for gas only. The higher compression will help alot. They did make gas pistons for that model,I'm not sure if the later pressed frame A pistons will work without some modifications ?
buickanddeere
02-22-2005 18:47:09
Yes the guy on the pulling site was telling you the truth. Put it on a dyno and find out if she is making even making stock HP before thinking about spending $10,000.00 to $15,000. Is it a gasser or all-fuel? What weight class and will she spin out in 1st gear before stalling as is? Boring 90 or 125 thou will not add any measurable HP other than restoring cylinder to piston leakage to acceptable specs. The larger carb would help if running a power block and stroker crank at rpms above stock.
