So long as the engine don't cough & sneeze under a load, I would say what you have is fairly normal. The path from carb to No. one is shrter than the path to No.2, and often times No.2 will go dry during idle -- thus will not fire. Also, I have found the champion D-21 the better plug of the two you mention. Read on below (PatB) Magnetos -- This is an area that frightens folks mainly because of lack of need to get into a magneto and fix it! Magnetos are tremendously reliable, and remarkably simple. Most need little more than to have preventive maintenance performed on them, and they work like a charm. Most usually, new points, condenser, rotor and maybe rotor cap replacement will do wonders for 9 out of 10 old magnetos. For troubleshooting and/or testing a magneto ignition system, follow the steps below. With a little imagination, these same tests can be performed off-tractor as a functional check. 1) If you remove the plugs but have their sides grounded and wires attached and you crank the tractor over, both plugs should produce a good visible BLUE spark -- not a faint, thin, whimpy, yellow spark! 2) To make sure it isn't the plugs, remove the plug wires and place their ends to between 1/8 & 3/16 inch away from the tractors steel; or use a known-good plug gapped @ 0.188 (3/16) inch. Crank the tractor over & over. You should see that BOTH output terminals produce that good visible BLUE spark? 3) If steps 1 & 2 fail, does the magneto make a good loud crisp snap sound as you crank the engine? If not and there's no spark, or a weak spark, the magneto's windup & trip spring assembly may be a problem, or it's just a weak spring. If the spring's weak, you may be able to pull start the tractor. Try that. 4) If there's no spark, or a weak spark but the magneto is snapping good, check the points for proper gap (0.015 for H) and replace them if burned, pitted, or carboned up badly! 5) Also, you need good wire-core plug wires, NOT the carbon-core suppressor types! But if end up with a dead one & cannot get it going, you can find help on the Internet. For magnetos, Robert's Carburetor Repair is a great bet. ++++
