12 Volt Seeder on a 24 volt system
02-17-2004 07:13:20
3010 D 24 volt system, where may I connect the 2 terminals for a 12 Volt electric seeder?
Thank You
buckeye al
02-17-2004 17:40:36
 Re: 12 Volt Seeder on a 24 volt system in reply to [email protected], 02-17-2004 07:13:20
Sorry it's so long. There are many variables though. The first thing to know is how many wires does the seeder motor have? IF it has only one, skip to the section ONE WIRE.
If it has two, go to the truck and connect it as follows. Connect both wires together, ground the motor case and then brush the wires against the battery's + post. If you get sparks under these conditions skip to TWO WIRES AND SPARKS. If it does not spark, go to TWO WIRES, NO SPARKS.
TWO WIRES, NO SPARKS.... Separate the wires and connect the black lead to the - post and the red lead to +. Take careful note of which way the motor runs. Switch the leads from post to post and see if it runs the same way or if it reverses. This is very important! Does it run the same direction regardless of which wire is connected to which post? If YES, go to TWO WIRE, NON GROUNDED CASE, NON REVERSING. If the answer is no, it reverses when the wires are switched, go to TWO WIRES, NO SPARKS, REVERSING.
TWO WIRE, NON GROUNDED CASE, NON REVERSING..... You can use either wire to ground and the other wire to either battery's non grounded post. Always be careful to keep your battery mounted clips away from the tractor's frame. You'll get sparks big time if the clip on the non grounded battery post touches ground. Suggest you use fuses and also do as Clooney says, switch from battery to battery occasionally to balance the load.
TWO WIRES, NO SPARKS, REVERSING..... This motor runs the right way only when the red wire is on a + and the black is on -. Here you must connect the black motor lead to either battery - post and red to that same battery's + post. Be careful to keep your clips from touching the tractor frame! Fuses are recommended in BOTH leads and it is advisable to periodically switch to the other battery to balance load. You COULD connect either lead to ground and the other to a battery post but to do so you must know which battery is + ground and which battery is - ground. Since this can be a bit confusing maybe it's better to avoid this type of connection by going directly to the battery posts. Yes it is possible but being more confusing it is therefore prone to an oops which might let the smoke out. We don't want to do that.
TWO WIRES AND SPARKS..... Since you have sparks from above, separate the wires, keep the motor case grounded and swipe the black wire across the + terminal. If you have sparks but no rotation, swipe the red wire across the + post. The motor probably runs so it will spark but not so intensely as the black wire did. Notice which direction it is running. Now isolate the motor case from ground and connect the black to + the red to - and see if it runs the same direction. If yes, see GROUNDED CASE, SAME DIRECTION. If no, the motor runs the opposite direction, see GROUNDED CASE REVERSING.
GROUNDED CASE, SAME DIRECTION.... This motor's case is grounded and if it is connected to the tractor's frame when in service, you can cap the black wire. You could if you wish for reliabilty sake connect the black wire to the tractor frame if the hitch is prone to poor connections. You can then connect the red wire to either battery's non grounded terminal. Be sure to use a fuse. Switch from battery to battery occasionally to balance the load.
GROUNDED CASE REVERSING.... With a grounded case and a reversing motor you have two choices. You can either connect the black wire to the tractor's frame or cap it then connect the red wire to the + post of only the battery that has it's - terminal grounded! You will not be able to balance the load as you will only be able to use one of the two batteries! The opposite battery will cause the seeder to run the wrong direction.
Your other choice under this GROUNDED CASE REVERSING condition is insulate the motor from the frame, put fuses in both leads and then connect the black wire to either battery's - and the red wire to that same battery's +. With the motor insulated from the tracor frame, you will be able to switch from battery to battery to balance the load.
ONE WIRE..... Given only a single wire feed, the motor case is obviously grounded. Connect the motor case to the truck - terminal and the wire to the +. Note which direction the motor runs. Switch the motor case to + and the wire to -. Does it run the same way? If yes, see SINGLE WIRE NON REVERSING. If no, it runs the opposite direction, see SINGLE WIRE REVERSING.
SINGLE WIRE NON REVERSING..... This situation is just like the two wire GROUNDED CASE SAME DIRECTION above with the exception that you do not cap any wires. If the hitch is prone to poor connections you could add a wire from the motor case to the tractor frame for reliability.
SINGLE WIRE REVERSING..... With a single wire reversing motor, the motor case must be grounded to a - post. You have two choices here. You can run this motor only using one of the two batteries. One way is to connect the motor's wire to the + post of the battery having it's - terminal grounded to the tractor's frame. The other way is to insulate the motor from from the tracor and/or seeder frame and connect a wire to the frame of the motor. Put a fuse in both leads then connect your new wire to either battery's - and the original motor lead to the + terminal of that same battery. With this arrangement you CAN switch form battery to battery to balance load but as always make sure you never allow the clips to contact the tractor frame.
John T
02-17-2004 20:07:20
 Re: Re: 12 Volt Seeder on a 24 volt system in reply to buckeye al, 02-17-2004 17:40:36
Lots of info there Al. I agree with your be careful of sparks !!!!! ! If he has a non frame isolated motor on the seeder which also has one of the motor terminals tied to the case and it gets to the tractors frame and he runs a wire tied to the seeder frame to a battery, he could be providing a short. Also, those reversible motors like permanent magnet motors could run backwards if wired wrong. One safer way if the seeder is wired non isolated and uses frame ground (for 12 Volts neg ground) and it gets connected to the tractor is to just use the negative grounded battery. If the motors isolated and not reversible type he could then be safer just using either battery, but I cant guarantee for darn sure just what he has. Im just afraid to advise him on all the different ways sitting here not knowing what he has for sure even though it may work fine. Better to be safe than sorry I always say.
Take care my neighbor to the East.
John T
buckeye al
02-18-2004 04:38:44
 Re: Re: Re: 12 Volt Seeder on a 24 volt system in reply to John T, 02-17-2004 20:07:20
Agreed. Probably easier to borrow a late model A, 60, a 1650 or 706 etc! Have a good day sir.
Clooney
02-17-2004 11:43:43
rrichardson, it's not that simple.. You really need to run a tap to both batteries [alligator clips work good]... Then just hook it up with the + wire from the seeder running to the + post on the battery on one side & the - from the seeder to the - on the battery ON THAT SIDE.. Then after you run it a while un-hook the one side & hook to the battery on the other side, again + from the seeder to the + on the battery being used & - from the seeder to the � battery post on that side.... Use only one battery at a time NEVER BOTH AT THE SAME TIME..
~If you try to run off of only one battery it will soon run that battery down & could possibly overcharge the other [non used battery] in the process..
~On those 24 volt series systems the battery load must be kept as even as possible or very uneven battery charging takes place.. [email protected]
John T
02-17-2004 09:39:36
The answer depends on whether or not the seeder uses a 2 wire totally isolated from frame ground type of motor,,,,, ,,,, or,,,,, ,,,, its a one wire which uses its own frame ground (which may well get connected somewhere somehow to the tractors iron frame). To be safe and not knowing sitting here exactly what you have, but assumign the seeders iron frame gets electrically connected with the tractors frame somewhere, heres how I have to advise.
I would use only ONE of the 12 volt batteries you now have, AND THAT WOULD BE THE ONE WHICH HAS ITS "NEGATIVE POST" connected to your tractors frame and its POS post wired to your starter. NOT the other battery which has its positive to frame. The 2 series 12 v batteries you have tie in the middle and that mid tie point is tied to the tractors frame so you can use 12 volt to ground lights etc. Using that 12 volt battery to supply the seeders 12 volt motor should work fine as the required voltage source PLUS keep you out of trouble in case the seeder uses its iron frame as its ground return path for a 12 volt neg grounded system.
If the seeder has a DC motor with 2 wires running out of it, maybe mounted to fiberglass or plastic and the motor is an isolated from its iron case type motor and theres no connection from the motors frame to the tractors frame, you can probably get by using either of the tractors 12 volt batteries to power it, but to be safe not knowing, go with the above advise.
You can use jumper wires or clips etc fed off the + post of the battery and the other off the -post (same as tractors frame ground) of that battery ran back to power the seeder. AGAIN just use the battery that has its - to frame ground and its + ran to your starter. Other sources to get that 12 volts neg grounded batteries power may be one of the big cable terminals on the starter/solenoid. That has 2 big cables to it, and the one to use is the one which is connected to a POS battery post, thats a source of 12 volts negative ground, and it and the tractors frame may be a handy connection/wirign point to the seeder (solenoid terminal + and tractors frame -).
Run 2 wires to the seeder, the 12 volts HOT + maybe off the starter/solenoid terminal and the other from frame ground. To be safe, you might add a circuit breaker or fuse right there where you connect to the hot + 12 volt neg grounded power, regardles if at the starter or battery. The size depends on the seeders load requirements.
SIMPLE AS THAT, 2 wires back to feed the seeder, + 12 volts and - to tractors iron frame FUSED OR PROTECTED supplied from whichever battery that has its NEG post to ground, maybe at the starter as a good wiring location.
Post back or e mail [email protected] or call me at 812-824-4608 any questions.
Good Luck n God Bless
John T
buickanddeere
02-17-2004 07:52:45
Do the seeder motors has a return path through the chassis/frame? Or back through a 2nd insulated wire? How may seeder motors? Two 12V motors in series run pefect on 24V, each takes half.
Bob
02-17-2004 07:29:56
Put alligator clips on the wires from the seeder. Connect to RH battery and run for an hour or so. Switch to LH battery for an hour or so. This keeps the power drain on the two batteries equalized. Be sure to have a power switch in the system, and be sure the seeder motor is shut off before connecting or disconnecting so you don't make a spark at the battery that could lead to a battery gas explosion.
