B model Radiator Filler Neck
5th Wheel
02-22-2005 13:34:04
If I heat the inside of the neck where it goes into the top tank and take a big pipe wrench to turn that neck out,will I break anything. I don't know how thick that top tank is???
Thanks
greenmech
02-23-2005 20:08:59
 Re: B model Radiator Filler Neck in reply to 5th Wheel, 02-22-2005 13:34:04
I wouldn't use heat, that would expand the neck. I would use a hacksaw and slice down to the top of the radiator, then use a chisel to bend in the ring, should come right out. Ron Mn.
mitchp
02-23-2005 20:06:26
you should be ok, mine was pretty bad, my welding guy had it out pretty quick, some of it came out in pieces. you'll need to heat it up some when putting the new neck back in there, DON'T drive it in with a hammer, you'll mess it up, you can lay a board across the top of it, and lightly tap it in.
miss b havin 36
02-22-2005 15:56:52
what kind of B do you have that has a neck like that?
5th Wheel
02-22-2005 18:03:26
 Re: B model Radiator Filler Neck in reply to miss b havin 36, 02-22-2005 15:56:52
42-45 model best we can tell. I already have a new filler neck for it. It is the big neck and looks like about an inch of it sticks above the hood. I have sprayed some pb blaster around it to soak but I was afraid that I would break the cast top of the radiator. Thanks
Soldier Tom
02-24-2005 17:15:13
 Where did you get the new one? in reply to 5th Wheel, 02-22-2005 18:03:26
Where did you get the new filler neck. The one on my 720 is about 3 inches above the hood and is OBVIOUSLY not the right one; but it DON'T LEAK so I don't want to bugger it up until I get hands on a proper replacement. Any help appreciated,
~Walk in peace~
Soldier Tom
