630 Compression
Terry
02-17-2004 07:01:13
wondering what these troctors had @new and what the min compression would be and still get them to start? If you were going to check the rings how much oil would you put in the cylinder? Thanks Terry
Ron
02-17-2004 13:12:13
 Re: 630 Compression in reply to Terry, 02-17-2004 07:01:13
I have a friend who has to spray WD-40 into the cylinders of his 620 and 530 about every spring, to get the rings to re-seal to get them to start.. After that, they start all summer long..!! They will probably start at 60 lbs if the starter is turning it over well.. Those old hand-start tractors start at a very slow roll-over--which would be less than 20 lbs..! If everything is OK, and you at least have "Some" compression, it should start.. Compression pressure at cranking speed for the Gas is listed at 132 lbs..
Terry
02-17-2004 12:21:11
Clooney or anyone else Help Please!
Thanks Terry
Also look at 630 wont start posted on 2-9-04 or2-10-04
