JD 36D loose fan shaft end play
Bob Blasey
02-22-2005 07:53:17
I have taken off the fan shaft because there is a lot of slack on the goveror end. I will replace both the front and back bearings. If the new bearings do not take up the end to end slack i thought of putting a washer as a shi. In the cup that attaches to the govenor case can I put a washer shim behind the bevel gear on the govenor end and the cone for the bearing? This will make the gear closer to the govenor gear and hopfully take out the end to end play. Does anyine have the same problem or experience
Glen in TX
02-23-2005 12:26:50
 Re: JD 36D loose fan shaft end play in reply to Bob Blasey, 02-22-2005 07:53:17
All the other comments sound good and should get you going. Not sure if I have any good D govenor gears left or not but can check if you need them. It is a time consuming job but worth it later. Something else to consider on the D is the length of the block. Many of them have had the front and or back side of the block shaved off for more compression and this affects the alignment also.
Maark
02-22-2005 17:39:54
The gov. shaft has nuts on both ends,loosen the left and tighten the right to move the shaft to the right. Same as the GP. But on a GP you need to remove the gov. housing to do that. You may have to remove the gov. housing on the D, turn it upside down and bolt the fanshaft on to get the correct heal and toe adjustment. Time consuming and a pain in the butt.
Bob B
02-22-2005 19:13:33
 Re: JD 36D loose fan shaft end play in reply to Maark, 02-22-2005 17:39:54
Maark: It does sound time comsuming. Have to mount the fan shaft and water pipe on at he same time? Little afraid of getting the timing marks (if any) on the gov.gear, and drive gear in the right cog. I removed the gov. on my 40D and was just lucky to get it in the right spot, Not any timing marks on the 40, so a little gun shy. this 36D has a base mount mag.timing is more dificult. But if that will solve the loose end to end play I may have to try it. At first I will replace both bearings. They are $36 apiece from JD, I have them on order
Maark
02-22-2005 14:05:00
You will probably need to adjust your fan shaft by adjusting the gov. shaft to the right.Along with shim gaskets where the fanshaft bolts to the gov. housing. If the gov.shaft is built like the GP, there are nuts on both ends of the shaft to adjust for lateral movement. The heal and toe of those gears need to be adjusted correctly or you will have a lot of gear whine in your fanshaft assembly, and also wear out your gears.
Bob B
02-22-2005 14:59:06
 Re: JD 36D loose fan shaft end play in reply to Maark, 02-22-2005 14:05:00
Maark: Thanks The D has gasket shims on the left end of the gov. I have only one thin gasket on that end. If I use more wouldn't it move the govenor gear further left. I think like you. The gov. gear needs to go RIGHT to close the gear distance to the bevel gear on the fan shaft. I have one gasket on the fan shaft too. More ideas? Thanks
Lee B
02-23-2005 06:04:35
 Re: JD 36D loose fan shaft end play in reply to Bob B, 02-22-2005 14:59:06
New gears is the only option left if removing shim gaskets don't get you to .010 or less free play there and they are expensive. Used would would work for you if they are not too worn out.
I hesitated to answer when I realized you might have a rubber mounted fan as my 43 A has the spring loaded fan clutch which keeps the fan shaft from moving at all. Unless the generator pulley is frozen to the fan shaft - only then does the fan shaft have any end play here. I&T manual just doesn't break it down good enough for me to know how your set up actually is, sorry if advise doesn't apply.
