630 axle grease
Rolla MO
02-22-2005 06:39:17
I have a 1958 630 gas and recently changed all the gear lube. I noticed on the top outer end of each axle housing there is a ~ 3/8 hex plug. Do I need to check this and if so what kind of lube does it take and can it be drained? Also how do you fill? What manuals are available to show this kind of information? Also when I pulled the second drain plug which I believe is the Transmission a couple pieces of gear teeth came out but everything seems to work OK. Any suggestions?
BushogPapa
02-22-2005 17:33:46
 Re: 630 axle grease in reply to Rolla MO, 02-22-2005 06:39:17
You really DO need a service manual...!!
There are other grease-points to service, too.!!!
If you have Manual steering, you must grease the front fan-shaft bearing, and there is one on the front pedestal (you have to remove the front screen section (Bonnet?) to get to it, and it is the same sized pipe plug...near the bottom--just above the frame... The distributor needs to have the oil leval checked in it too... Like I said, you NEED a manual..!!!
Ron.
Rolla MO
02-23-2005 04:51:00
 Re: 630 axle grease in reply to BushogPapa, 02-22-2005 17:33:46
What is the best manual and where can I get one?
BushogPapa
02-23-2005 06:46:37
 Re: 630 axle grease in reply to Rolla MO, 02-23-2005 04:51:00
John Deere has basicly "re-prints" of the original manuals, only in a larger size that is punched to fit a 3-ring binder (for safe keeping).
Enjoy the fine specimen of a 2-Cylinder...!!!
Ron..
Mike M
02-22-2005 08:11:47
Those outer 3/8" plugs can come out and you put a grease fitting in there and pump some grease in there,not a whole bunch,then you can put the plugs back in if you want. On those gear teeth pieces someone must of been shifting on the go at sometime.
