Hi b&d, What about 195 to 225 if that's the red part of the gauge range? I remember in the'70's GM cars and trucks had a 196 thermostat. Course these were gas. That's not all that hot for a pressurized 50-50 cooling system, nor today's engine lubricants. Agree about the higher temps helping the diesel to run clean and efficient. Have no indication that the tractor is unhappy. No smells, engine smooth, crisp response from the controls, great acceleration from the pump. Got the factory part number and ran a cross ref to dimensions. Says the correct diameter is 2 1/8. I guess tubing is measured by the OD rather than ID, cause there is thick wall and thin wall, 16 ga up to 10 ga and all. So that is another check that I have a stock setup. Maybe I'll wait and see. First time to load up the tractor and just don't know what to expect. My real concern was that it was cool outside (60)and I didn't have the AC on. I realize I was pulling an 18' JD Spike toothed harrow in a mid range gear with the engine near pto rpm's. Just felt like either I was overloading the engine or I had cooling problems. What was it going to do in July pulling a round baler or plow with the AC on was my real concern? One thing I noticed was that it has 18.4 x 38 rears where the orig wheel is spec'd at 18.4 34's (per this and other tractor data sites). That would give me a lot more tire circmuference and that could cause a lugging effect meaning that maybe I was in fact in too high a gear and dropping down would cool things off. Course I don't know what kind of variances they offered with new tractors in terms of wheel sizes. I know some offered row crop types or utility depending upon usage. Thanks, Mark
