Another Mag test stand question
430WLPG
02-21-2005 17:21:31
I found the base mount bracket for my tester, but now what does the drive coulping adapter look like,anyone have one to take a picture of? Thanks
Glen in TX
02-23-2005 12:09:04
 Re: Another Mag test stand question in reply to 430WLPG, 02-21-2005 17:21:31
430WLPG
You can use the phenolic fiber floats for the mags like Duane is describing. If you are needing the float puck coupling for the Allen tester that is round with the holes in it you can make that easily from a round of UHMW plastic. Color of plastic doesn't matter. I also have a large piece of phenolic to cut them out of also. If you need pictures of it still let me know or I can scan them too.
Duane Larson
02-22-2005 14:00:16
430WLPG,
The flange mount magnetos require two drive couplings, a long one and a short one to accomodate short and long lug magnetos. When using the base mount configuration the same long coupling is used.
430WLPG
02-22-2005 17:16:48
 Re: Another Mag test stand question in reply to Duane Larson, 02-22-2005 14:00:16
thanks,Duane
