4040 cab liner
gordon hulgan
02-21-2005 13:17:41
installed cab liner foam,cloth is this 1pice or twopice job can old dirt famer do this? thank.
G/MAN
02-21-2005 15:59:12
 Re: 4040 cab liner in reply to gordon hulgan, 02-21-2005 13:17:41
If you're talking about replacing the upholstery, it's not too hard. Removing the seat from the base makes it infinitely easier (it's also easier to make some studs to remount the seat to the base when going back together, as the bolts can be a pain to get started) and provides a lot more room to work. Getting all of the old upholstery out and the old glue off is the hardest part. Good scrapers and maybe some sort of adhesive remover (don't remove the paint) are a must. I've never scraped one all the way down to the metal. As long as the surface is relatively clean, the adhesive will stick. And when installing the new pieces, be patient and do a little at a time, because once that stuff is stuck, it's stuck for good, and you'll ruin it trying to pull it back off. That 3M adhesive is some wicked stuff. I like to get a panel glued in one area and then sort of work out from there instead of sticking the whole piece at once. Patience is the key, and the willingness to accept one or two wrinkles here and there helps, too. If you do end up with some minor wrinkles, they seem to go away with time. And I'd take a slightly wrinkled new interior over a hashed, rotten old one any day.
