830 pony leaking oil into diesel
Ron Sharpe
02-21-2005 07:48:14
Why is my pony leaking it's crank case oil into the diesel engines crank case?
Carl NY
02-21-2005 10:01:10
 Re: 830 pony leaking oil into diesel in reply to Ron Sharpe, 02-21-2005 07:48:14
Ron, thats because thats where the pony motor oil ends up when you change it. The pony motor oil drain plug is ether loose or not seated properly. If you don't have one , you need to purchase an operaters manual for that model tractor.
Chuck in Ks.
02-21-2005 11:46:14
 Re: 830 pony leaking oil into diesel in reply to Carl NY, 02-21-2005 10:01:10
Ron, Carl is correct. Maybe someone can post a picture so you can better understand what Carl was talking about, meanwhile, you need to pick up an operators manual as soon as possible.
F-I-T
02-21-2005 13:03:22
 Re: 830 pony leaking oil into diesel in reply to Chuck in Ks., 02-21-2005 11:46:14
third party image
The o-ring is likely the problem. THey get hard and brittle after a while.
