Dads You are on the right track for checking things. Here is how I would proceed by the seat of my pants. after you filled it to the test drain in the back, run it some and check it again. If it had been low before it may have pumped some into the system. Also, if the oil runs out the test cock after or while runup look for a lot of foam, that probably means that air is being sucked into the system via somewhere along the big return tube. If you got dual tom, make sure the valve is set right and you are using the correct up and down lever. If all goes well so far go to the remote and see if she will squirt oil out there or work if you have a cylinder to hook it to - or the loader if it is mounted. nothing there, go to where the pressure line first hooks into the rear (I think that would be the romote and crack the fitting loose and see if oil squirts out there and if so is it milky/foamy. That stuff running out the belly should either be engine oil or trans oil or both since the hyd doesn't go anywhere in there. Also your tractor should have the totally separate rack and pinion power steering and it not be related to the tom either. Let us know how it goes this far and we can go from there. Just a side thought on a loader, if you have just worked on it or reinstalled it and a lot of oil had run out of it, it took me forever to get all the air worked out of that system by adding and working the lift.
