JD 50 head stud lead washers
Tye
02-20-2005 10:43:35
I took off the valve cover from the 50 this morning to adjust the valves and noticed the lead washers under the stud nuts. One of the washers (or lack of) was missing half and I gently removed the other half from around the nut. The nuts are all tight and to the best of my knowledge, no coolant is leaking from around the studs. Before I replace the valve cover should I replace these lead washers? Or is there enough lead stuffed under the nuts to keep things from leaking? Thank you for any help with this one. --Tye
JGC
02-20-2005 11:15:50
 Re: JD 50 head stud lead washers in reply to Tye, 02-20-2005 10:43:35
If you are sure that the nuts are all torqued corrected and that nobody has disturbed them, you should be fine. There should be enough lead squished under the nut to seal around it. I was told to cut the excess lead off around each nut because fragments could break off with vibration and get into the oil. You may find that 1/2 lead washer lying in the bottom somewhere.
JGC
