4020 Parts Manual
Silver Pig
02-19-2005 19:20:12
Looking thru the parts manual (PC1116) for a late (SNT213268XXX) 4020 I came across the following and was wondering what they are:
AR101616/AR103363 (3E-19/3E-16) Anti-Friction with/without differential lock kit.
3E-9 PS/3E-10 SR Increased Oil Filtration Kit (Dual Filter)
3F-4, 3F-5 Final Drive Kit 51mm (2inch)wide
3B-19 Counterweighted PTO Clutch Operating Kit
Also, has any used the fender kit for the front wheels on a 2WD 4020? Is it the same as for the later MFWD tractors?
RickB
02-20-2005 05:15:07
 Re: 4020 Parts Manual in reply to Silver Pig, 02-19-2005 19:20:12
The counterweighted PTO clutch kit is PTO fingers with weights to keep the fingers off the thrust bearing when not in use. Also may be some PTO valve modification needed. Don't know about the rest.
