2940 rear hydralics
Costello
02-19-2005 16:35:37
I lost all rear hydralics on 3. hitch and rear aux. Please help
Gord
02-24-2005 23:20:36
 Re: 2940 rear hydralics in reply to Costello, 02-19-2005 16:35:37
If the rear hydraulics have quit but you still have power steering, then the main hyd pump standby pressure has fallen below 1700 psi. The priority valve will shuttle forward to shut off the rear hyd to save hyd pressure for the steering. The main hyd pump pressure may have to be adjusted to 2350 psi. That is providing that the filter has been changed and the screen in the transmission has been cleaned.
Costello
02-25-2005 18:02:04
 Re: 2940 rear hydralics in reply to Gord , 02-24-2005 23:20:36
Let me tell you how this happened..I have an 8 ft snowblower on it, moved shoot and the hose blew, since that point i have nothing, i"ve changed the filter, cleaned the screen, changed the oil, still nothing, should I still look at what you suggested? Soppose to Snow bad this weekend.. any help would be greatly appreciated! Thank you
cannonball
02-20-2005 06:10:35
do you still have power steering...if not front pump shaft coupling striped out, there are a number of things it could be ..transmission pump supplies front pump...have you tried filter -screen .. really need more information...have nice day may god bless
costello
02-20-2005 15:12:46
 Re: 2940 rear hydralics in reply to cannonball, 02-20-2005 06:10:35
Power steering still works, changed filters and oil. I need help please.
cannonball
02-22-2005 06:24:44
 Re: 2940 rear hydralics in reply to costello, 02-20-2005 15:12:46
will the lift work if you turn steering while trying to lift? if it does your stroke control valve might be sticking... have nice day may god bless
Costello
02-23-2005 16:28:27
 Re: 2940 rear hydralics in reply to cannonball, 02-22-2005 06:24:44
I havnt Had time to try it. I will over the weekend and be sure to let you know. Thanks Alot.
