345 won't start; out of gas; prime?
bradley
02-19-2005 15:59:56
My neighbor borrow my JD and ran it out of gas. It's the twin water cooled 345 model. does it need to be primed; is it fuel injected. it turns over but will not start. any suggestions? thanks. Brad.
jd b puller
02-20-2005 10:47:54
 Re: 345 won't start; out of gas; prime? in reply to bradley, 02-19-2005 15:59:56
Where do we start...Keep going until you find the problem.
1. Do you have spark?
2. Fresh (clean) gas? Newer Kaws are particular on their gas. 87 octane and fresh
3. Disconnect the line from the fuel pump to the carb. Get a coffee can and let it dump in there. Any gas when you turn the engine over?
4. If no gas from step 3, take the line that goes from the tank to the fuel pump off. Run a new line from a small container to the fuel pump. Any gas in the coffee can when you crank it over now? (NOTE: you will want to keep cranking long enough for it to pull vacuum to pull the fuel up.)
5. If it does, check your fuel filter or maybe there is gunk in the tank.
6. If it still doesn't pull fuel up, then fuel pump may be bad.
duff
02-20-2005 15:47:47
 Re: 345 won't start; out of gas; prime? in reply to jd b puller, 02-20-2005 10:47:54
JD B Puller,
thanks for the input. It sure does sound like something got clogged up as it ran fine before it ran out of gas. I did put new plugs in to be sure and will follow up with the other steps you mentioned. thanks.
Duff
