4440 quad range
B crazy
02-19-2005 15:24:01
The 4440 has to go to the shop for a transmission clutch pack and transmission pump replacement. Question is barring any unforseen problems ,approximately how many hours labor am I looking at in the job. A Deere dealer will be doing the job for I have no way to remove the cab
twopop
02-20-2005 07:05:27
 Re: 4440 quad range in reply to B crazy, 02-19-2005 15:24:01
well,i think i had a brain freeze on this one.i was thinking of a power shift clutch pack and the trans pump.the jd manual says to remove cab if working on the trans,you would just split it if you were working om the two speed planitary(sp)the other confusion was working on the trans clutch pack and the trans pump,as there is no connection between the pump and the trans clutch pack and the trans pump.the trans cluch pack is not hydraulically control.
what is wrong with the trans?
twopop
02-19-2005 15:36:52
you dont remove cab,just split it
B crazy
02-19-2005 16:05:39
 Re: 4440 quad range in reply to twopop, 02-19-2005 15:36:52
shop foreman told me that the cab had to come off to get the transmision out .Said that you had to go in the front side of the transmission to get to the clutch pack. Looks to me that the cab will have to come off to get to the front of the transmission
agri_con
02-20-2005 04:31:28
 Re: 4440 quad range in reply to B crazy, 02-19-2005 16:05:39
Will say for the short amount of time it takes to remove a cab on this model,its better off,sure elimates some big hassels,and truthfully never seen one done with cab on.
Will Dave
02-19-2005 21:29:30
You do not remove the cab to repair transmissions on 4440s. You can if you want to, but it is not necessary.
cobroller
02-19-2005 23:46:18
 Re: 4440 quad range in reply to Will Dave, 02-19-2005 21:29:30
Twopop & Will Dave are correct. You can also remove the rockshaft housing and get to the transmission pump without removing the cab.
