1935 BR Clutch - Worn Toggles/Dogs
PRW-IN
02-19-2005 14:57:02
My 35 BR doesn't snap across the way it should (it just kind of sticks in), although the clutch seems to operate OK. How much play is acceptable in the Toggle and Dog links? This setup is different than the General Purpose B's (similar but different). The links that attach the dogs to the nubs on the pulley appear to be 3/8 inch pins - these have about .002 inch of wear. The holes in the dogs that these links go through have about .005 inch wear (from a nominal 3/8 inch). The links that attach the dogs to the toggle bolts appear to be 1/2 inch pins with about .007 inch wear. Also, how much wallow is acceptable in the operating sleeve pin and operating sleeve? The outer edge of the operating sleeve will move about 1/8 inch from the wallow.
Thanks to everyone in advance!!
Mike M
02-21-2005 11:30:24
 Re: 1935 BR Clutch - Worn Toggles/Dogs in reply to PRW-IN, 02-19-2005 14:57:02
What happens when you tighten up the three adjusting nuts evenly ? Use a torque wrench 10-12 lbs should do it.
