40 T or Farmall Super A
Daniel
02-16-2004 20:15:48
I have an on going debate with my neighbor comparing the Super A to my 40 T. He keeps trying to convince me that the Supe A is a bteer tractor. Stronger pull 2 disk plow and better for cultivating small truck farming operation.
I would like to hear some your expert opinions on this subject. I know you fellows have alot farming experience and could offer insight onthis topic.
Thanks,
Daniel
buickanddeere
02-17-2004 10:39:59
 Re: 40 T or Farmall Super A in reply to Daniel, 02-16-2004 20:15:48
The gas A & Super A were Nebraska tested in 1939 at 16.51 belt & 15.7HP drawbar weighing 3570 lbs as tested. The 40 gas was rated 23.61 pulley & 21.01HP drawbar weighing 3219lbs as tested.
lc
02-17-2004 06:36:42
Don, my dad farmed with mules, then a farmall cub for 2 yrs, then a super a 1 yr, then a jd40t, which i have today. Mules, i dont care for, cub i don't care for, Super a was a fine little tractor. Also the jd40t. I would judge the jd as some stronger power wise. The super a i would judge as a better 1 row cultivator tractor. I never thought the jd cultivators worked as well as they should. They were the spring tooth variety. Others may be better. I wish i had a super a go go with the jd40.
don wisc
02-16-2004 20:44:53
Your question is like debating Fords and Chevys.
The Super A is better for single row cult with the off set engine and is also much easier to get on and off.
Your 40T being a 2 row also has a good view.
Power wise I think they are both pretty close, I would have him put up or shutup by you both pulling a common implement like a disk or spring tooth and see who pulls it deeper or faster and let us know.
One thing for sure IH sold a lot more A thru 140s than the equiv JDs but they established the market long before JD had the M. The L and LA did not compare.
