JD 40C Three point
JDAOS
02-19-2005 09:18:19
Would appreciate someone posting a picture of a 40 crawler three point setup. Trying to determine if the one I found is factory.
Lavoy
02-21-2005 17:52:13
 Re: JD 40C Three point in reply to JDAOS, 02-19-2005 09:18:19
The one you posted is not a factory set up, it has some factory components, but is most likely a shop built hitch.
If you go to my website, there are some pics of crawlers with the factory 3PT.
Lavoy
DiggerLarry
02-21-2005 10:44:46
The 3 point was not available from the factory on a 40. When it became available on the 420C in 1957, JD offered a retro-fit for the 40C that the dealer or owner could install on the 40C or '56 420C.
JDAOS
02-21-2005 12:28:50
 Re: JD 40C Three point in reply to DiggerLarry, 02-21-2005 10:44:46
Digger Larry, Do you know if the retrofit three point was the same as the 420C or could it have looked like the one I posted on the tractor photo gallerie? Thanks Bob
johndeeregene
02-20-2005 20:20:03
it is not factory i know because they did not put a 3 point on the 40 crawler. it is probably a 420 set up. johndeeregene
JDAOS
02-21-2005 08:10:08
 Re: JD 40C Three point in reply to johndeeregene, 02-20-2005 20:20:03
Thanks for the response. It must be a after market setup as it is different than a 420 three pt. I am posting a picture of it in the tractor photo gallerie.
