2510 vs 3020
JD Doug
02-16-2004 20:04:41
Set a 2510 next to a 3020 and I can't tell the difference. So, what is the difference?
Dan
02-18-2004 10:39:09
 Re: 2510 vs 3020 in reply to JD Doug, 02-16-2004 20:04:41
Doug, I grew up with a 2510 D that my Dad still owns, and the biggest difference is Hp. My father-in-law has a 3020 and I have run both tractors pulling the same size 4-16 plow. There is not as much difference between a 2510 and a 3010.
HOOSIEr
02-17-2004 19:37:04
2510 has same rear axles as 3010.
Rodney A Johnson
02-17-2004 07:50:14
With the diesel versions there are quite a few differences that I noticed. Placement of the starter for one...on right side instead of left side. The oil filter is up on the engine and is a spin on external filter vs. the internal element. Placement of the fuel filter was different (and different style), but then there are different from 3020 to 3020 as well.
I thought the 2510 sat lower down than the 3020, and as far as HP, the 3020 has a more 12-13 more stock HP (52 vs. 65 if I recall correctly). I'm guessing, but don't know, that the 3020 weighs in a lot more than the 2510.
All these differences are fairly cosmetic. Both are good tractors.
John
02-16-2004 21:03:37
The engine in the 2510 is the same as the engine in the 2020. The 3020 has a larger 4 cyl. that is the same as the 4020 minus 2 cylinders.
