1938 AR push rod tube with drip
Marty Z
02-18-2005 21:59:43
I have a left cyl. push rod tube that has a very minute leak. There was a slight bit of crust around the valve cover side. It showed no water in oil. It was filled with anti-freeze when I took it apart,,which I know finds it's way into all leaks. I would like to try to expand the push rod with a tapered punch and see if that fixes it.. Then fill it with plain water when I get it back together.. What do you think ? I have been watching the push rod posts and wondering.
Thanks Marty Z
Curtice Ohio
Mike M
02-19-2005 04:12:02
 Re: 1938 AR push rod tube with drip in reply to Marty Z, 02-18-2005 21:59:43
Expanding it and filling with water will more than likely work.Fill with anti freeze it may still leak ? Filling with water in Ohio this time of year ? Recipe for disaster,I have seen this many times. Very easy to forget to drain or putting plug back in right after draining and then bust up everything. You could pull out just that one and maybe even reuse it after a good cleaning up and some JB weld to seal it up. I pulled mine right on the tractor. I made a puller out of pipe and all thread and a larger piece of pipe to go over the outside and pull tube into it. I ran a pipe tap into the tube and put some threads in it to screw the puller into. I would just buy new ones and replace them all.
marty Z
02-19-2005 11:10:57
 Re: 1938 AR push rod tube with drip in reply to Mike M, 02-19-2005 04:12:02
OK Mike,
Looks like I'm gonna make a puller. Never tried removing the push rod tubes before. This one is a total tear down so I probably won't have fluids in it till summer. The only tractors that I have antifreeze in are the D and the 8-N for winter use. I drain the others for the winter and leave them open ,stored inside.I think I can picture your puller from the description.
Thanks.
Marty Z
