410d backhoe loader
browser269
02-18-2005 20:55:25
I"m looking at an older 410d backhoe loader for sale. Looks to me like someone was real mad about giving it up and did their best to sabotage major components prior to losing it.
I think if the machine was gone over now and repaired prior to returning to normal service it may be fine but it has a real problem in forward gears. The clutch looks like it should have a lever/linkage connection to the front of the transmission. It"s not connected. Would this cause performance issues going forward? If I manually controlled the disconnected piece would it allow me to move forward and show the clutch as good? Thanks for any help.
Roy Suomi
02-18-2005 22:52:59
 Re: 410d backhoe loader in reply to browser269, 02-18-2005 20:55:25
You have a straight 410, not a 410-D. The D means it was built in Debuque Iowa.When you go for parts please be sure you use the correct model number.. That rod that isn't hooked up is the clutch disconnect linkage. It should be hooked up for cold weather starting.Adjust the rod so that the clutch bearing just contacts the pressure plate fingers when you flip up the pedal stop on the clutch pedal. the clutch pedal only shuts off oil at the top 4 or 5 inches of pedal.
browser269
02-19-2005 18:45:06
 Re: 410d backhoe loader in reply to Roy Suomi, 02-18-2005 22:52:59
Thanks for helping with the model number that is valuable information. I believe from your response that that linkage being MISSING would not result in the slippage in forward gears. If you check back let me know what you think.
