50 paint
rej
02-18-2005 17:40:50
I was thinking about painting the rear wheels and rims on my 50 this weekend. Been working on it since Christmas and am almost finished. Temperature here will be about 55 F,sunshine and low humidity. I'll be inside a building and will be using JD paint. My question,is the temperature to cool to put on the paint? What are the after effects? thanks, BJ
jeff 2030
02-18-2005 18:52:23
 Re: 50 paint in reply to rej, 02-18-2005 17:40:50
I would not even think about it at 55 degrees
Pat Browning
02-18-2005 18:36:48
I agree that the 70-degree rule be met. There are always exceptions, but where you are also fighting humidity, you should have both the metal and air temperature at or above 70. (PatB)
Dan in Ohio
02-18-2005 18:27:53
rej,
I would not paint when its that cold, I like 70 degrees and that means 70 degree sheet metal and cast parts not just air temp. I do not worry about the humidity, living in Ohio you can't do to much about it any way. In the spring I usually leave the heat turned on in my shop the night before I paint. Painted my 70 last year in the winter and had some problems from painting when its too cold.
Mike M
02-18-2005 18:08:48
I once painted some parts for my unstyled B and it was colder than that. I think they turned out better than most times. Freeze dried I guess ? Could really dump the paint on without runs.
