1010 hydraulics
hank n' tx
02-18-2005 16:14:37
i'm looking at buying a nice jd 1010. it has a few hydraulic leaks. the main leak is on the left side, under the seat, at the top of the hydraulics. does anyone know what could be causing this and how difficult it would be to fix? also the seal needs to be replace at the pto shaft. there are 3 bolts there. will the shaft come out after removing the three bolts? the last thing is the pto wont disengage. what would be causing this and where do i get to it. this is my 1st john deere. i will purchase an i t manual but any help will be greatly appreciated. thanks hank
Loren NC
02-19-2005 03:33:37
 Re: 1010 in reply to hank n' tx, 02-18-2005 16:14:37
I also have a leak under the left side of my seat but haven't addressed it yet. Just have a rag tied around it so I can't tell you about the fix.
Turning off the PTO is likely just a clutch adjustment. The manual you will get will tell you how to do that.
You don't have to take the PTO shaft out to fix the leak around it. You can buy the seals from J-D for $22 each or get generic ones from your local bearing house for about $7. Just stick a screwdrive in beside it and pry it out, then slide the new one on. With it not running, you can remove the seal and go buy a new one without losing any significant amount of oil. The seal on my 1010 is a National 481122SSR CR#17284. There are differences in 1010 models. Mine has the shift on the floor in the center of the tranny case. My PTO lever is a long lever on the left side beside the clutch. There is a plate under the clutch pedal that you take off to get inside to adjust the PTO clutch.
Wayne in Tn.
02-18-2005 16:33:11
 Re: 1010 hydraulics in reply to hank n' tx, 02-18-2005 16:14:37
Hank, I have never owned a 1010, but this was the first of its design, when the 2 cylinder 430 and 435 was dropped. I do not want to offend any 1010 owners, but I have seen lots of posts by collectors calling this model a "lemon" I would check it over good and make sure the price is "right". The 40, 420 and 430 models are the ones that I collect or work on. They have a few common problems such as leaky rockshafts, loose steering and gear noise, but overall they are very tough and dependable little tractors.
