2440 and HYD
GoatRoper
02-16-2004 19:14:48
Ive been looking at a 2440 that will fit my needs to a T but Ive herd that the 40 series had weak hyd. Ive spent alot of time searching posts and havnt read anything of the sort. Any 40 series owners not satisfied with their tractors hyd? Thanks
GoatRoper
02-17-2004 13:28:48
 Re: 2440 and HYD in reply to GoatRoper, 02-16-2004 19:14:48
Thanks for the quick responces. Now, all that is left is some wheelin and dealin with the local dealer. Thanks again
John
02-17-2004 05:48:37
Ive got two 2440`s. One with 1200 original hrs and the other with at least 10,000 hrs. 1200 hr one has been welltaken care of. The 10,000 plus one has had a tough life. (multitudes of migrant operators) Resleeved/valvejob/clutch at 6000 hrs. Picked up a rap noise at 8500 hrs and is still running reasonably strong at over the 10,000 hr mark. No hydraulic problems at all. Key seems to be regular oil and filter maintainence. Rap seems to be injector pump related as a crank/rod bearing inspection showed no undue wear.Injector pump goes to rebuild shop later this week. Been a good machine in all respects and I`d like to think its good for a few thousand more hours.
Indydirtfarmer
02-17-2004 03:41:01
I've got a 1978 2440. Never had a single problem from the hydraulics. Great tractor. I do, on a fairly regular basis, change hydraulic filter(s) an oil. Usually every couple years. You'll like the 2440. Lots of power in a small package. John
Rick
07-14-2004 13:12:04
 Re: Re: 2440 and HYD in reply to Indydirtfarmer, 02-17-2004 03:41:01
I've got a 2440 with 2000 hours which I've owned for about a year. I love it but I can confirm it does have weak hydraulics. Haven't done the troubleshooting steps in the manual yet to see if it is a pump problem but the fluid is new and the filter and screen have been changed.
