ALL FUEL HELP NEEDED
Tyler-MO
02-18-2005 07:36:39
I"m seeking out several parts for an all fuel 520 tractor. If anyone out there knows anyone with a parts tractor, experience locating parts for all fuel tractors, or just a person that has or specializes in all fuel types; please let me know. Thanks,
Tyler in Missouri
Walt in Jaxn Tn.
02-18-2005 21:24:25
 Re: ALL FUEL HELP NEEDED in reply to Tyler-MO, 02-18-2005 07:36:39
what parts do you need? --Walt--
Tyler-MO
02-19-2005 05:57:06
 Re: ALL FUEL HELP NEEDED in reply to Walt in Jaxn Tn., 02-18-2005 21:24:25
DTLX96 Carburetor
Fuel lines from gasoline starting tank to carb
all fuel 520/530 pistons oversize .045 new or good used
all fuel manifold heat exchanger valve
Let me know if you can help.
Thanks,
Tyler
Walt in Jaxn Tn.
02-19-2005 09:29:17
 Re: ALL FUEL HELP NEEDED in reply to Tyler-MO, 02-19-2005 05:57:06
Reason I asked, I've got a 1954 all fuel "50" pretty much complete "running", needs radiator core, battery box seat box, right rear hub (F 1500 R fits "60" and "70" also) generator. I bought many parts and services meaning to restore this tractor to burn kerosene but decided I had too many irons in the fire to get everything I have restored It's one of 1500 built but I only have seen this one, all the others must have been scraped or converted. It's serial # is 5016218 and the carb is DLTX 83 I believe, the duplex manifold is one piece. It also has two piece front end weights A 5346 R and A 5347 R and lift arms P 816 A . No power steering, It's got a john deere exhaust pipe (one continuous smooth 90 degree turn instead of two 45 degree turns as aftermarket exhaust pipes are) Does not have a muffler but is the quietest 2 cylinder(no engine noise and no transmission noise) a friend of mine said! --Walt--
Tyler-MO
02-19-2005 09:36:25
 Re: ALL FUEL HELP NEEDED in reply to Walt in Jaxn Tn., 02-19-2005 09:29:17
Email me at [email protected]
I would like to know if you would want to sell it and if so what you are asking.
Thanks,
Tyler
