jdemaris
02-17-2005 19:45:09
Re: JD 1010 what to look for ctx in reply to Gregg in ohio, 02-17-2005 16:27:24
I don't see too many 3 point hitches or PTOs on backhoes - but I guess it's possible. As far as the price goes, just about any backhoe that runs seems to bring at least that much. I passed up a Deere 2010 wheel loader/hoe here in my town. It ran, was pretty beat, the guy wanted $4000, but I passed it up. Now a used equipment dealer bought it for resale and is asking $5500. When it comes to 1010 and 2010 industrials, there are a lot of variations - so I don't know what this one has for a trans. I'd check the following known weak points. Brakes - they barely worked when the machine was new and usually don't work at all on used machines. Rear wheel hubs - many had cast hubs that were separate from the axles. They came loose and got worn out. See if it has the separate hubs, and if so, see if they wobble on the axle. After awhile, they strip and the machine won't move. Backhoe swing cylinder - look to see if it's a single "barrel" type cylinder instead of having two separate conventional swing cylinders. They were, and are - junk. Very weak swing power and chronic leakers. We worked on them constantly when they were new - and they don't get better with age. Engine - you didn't mention gas or diesel. Gas engine is basically the same size as the 420 two-cylinder engine and not very powerful. Run it and check for blowby out the breather pipe. If you suspect the engine is worn, keep in mind that parts are MORE expensive than the average Deere engine - and most have to come from Deere - no aftermarket available. Power steering - check to see if it works after the machine gets hot - it's a bad system. There are obvious good points also - but - if you want a Deere backhoe that size, you'd be miles ahead with the later 300 backoe. It is basically a 1020 ag. tractor in industrial version. MUCH, MUCH better machine than the 1010 and parts are easier to get and cheaper. Bigger and better engine, closed-center hydraulics, wet power brakes, optional hydraulic reverser, etc. I think Deere made a mistake by following the 1010 with the 1020 designation because they have nothing in common except for size.
