Head for JD B
Steve Arnold
02-17-2005 15:59:16
Is there anyone making cast parts for two-cylinder John Deeres? I have a '36 B in need of a new cylinder head. I have had very poor luck locating a good used one, as they are all about 50 years old or older. If anyone has any suggestions, I will be greatly appreciative of any help.
JD-Tractor
02-17-2005 18:17:27
 Re: Head for JD B in reply to Steve Arnold, 02-17-2005 15:59:16
Are you sure it's not just the push rod tubes?
miss b havin 36
02-17-2005 16:10:52
what is wrong with your old head?
Steve Arnold
02-17-2005 18:09:52
 Re: Head for JD B in reply to miss b havin 36, 02-17-2005 16:10:52
it is leaking antifreeze out the top, not near the head gasket. Must be cracked internally.
Will P
02-17-2005 19:30:55
 Re: Head for JD B in reply to Steve Arnold, 02-17-2005 18:09:52
You did check the push rod tubes, right???
Will P.
easydoesit
02-18-2005 08:11:40
 Re: Head for JD B in reply to Will P, 02-17-2005 19:30:55
Hey Will P, Where do you get unst B pushrod tubes? The last ones I bought from deere had the right part # but wouldn"t fit the hole. easy
Mike M
02-18-2005 09:23:46
 Re: Head for JD B in reply to easydoesit, 02-18-2005 08:11:40
I got some from Deere a couple of years back.My head has 4 holes and none of them were machined the same size from the factory. I think one they fit right,slight press fit ,the others were loose to varing degree I did this on the tractor so I didn't want to pull it off and have them custom made so I used JB weld smeared on them and in the holes to tighten them up.
easydoesit
02-18-2005 13:34:05
 Re: Head for JD B in reply to Mike M, 02-18-2005 09:23:46
Thanks Mike, I didn't know if it were just my luck or others have problems with the fit on these. My problem started when I went to deep tapping a manifold stud. Shoulda known better! I think that I will try to have some tubes made. Anybody want to make a bunch...I'll buy some. easy
Mike M
02-18-2005 18:20:43
 Re: Head for JD B in reply to easydoesit, 02-18-2005 13:34:05
I think the machineing on these old heads was crude by todays standards. Mine would have required about three different sizes.
miss b havin36
02-18-2005 16:14:05
Old Steve has not responded, must be checking his tubes? I have used Deere tuber and soft copper both, usually use a plumbers swedge to get them tight.
Jon C- Florida
02-18-2005 15:51:23
Wil P is correct...those push rod tubes must have a tight seal. There seems to be a very slight taper on one end of the tubes, and they should be slid in from the proper side of the head. I have slightly honed the cast holes with emory paper, and then applied gasket goo to the holes to get a tight fit after pressing them in. In my opinin, nine times out of ten its the push rod tubes that give all the grief of water in oil. And yes, your correct, you need to watch the tightening of the studs in two of those holes...make sure you blow the crud out of the bottom of the stud hole or it will crimp the tube. You can get those tubes over the counter with no problem, and should not have to make them.
Will P
02-18-2005 14:32:51
Well, I program, set-up and run a cnc turning center and vertical mill. The problem is, what is the exact size you need? I would have to have the head to get the exact measurement.
Will P in WI
johnnypopper_44
03-07-2005 10:44:27
 Re: Head for JD B in reply to Will P, 02-18-2005 14:32:51
I put in new tubes when I put it together the first time and the second time. I seal them, but I'll try to see if mybe they are getting crimped on the end...never thought to check that. probably shoulda been my first thought. thank guys, i'll let you know how it comes out
