5300 intermittent tachometer
Gatractorman
02-17-2005 14:37:28
Hello folks, a gentleman called me today on a 5300 think he said '95 or '96 model and his tach only works sometimes, so I removed the dash and found it to be one of those all-in-one instrument clusters where you just attach appropriate wires to the appropriate place to make the guages work. I found that I do not have power from the cluster on the wire that ultimately goes to the RPM sensor. Is it possible to get into the cluster to do any work on it or would he be better off replacing it and if he replaces it what do you do about the hour meter reading? Just remember to add the amount this one shows to the new one? Thanks for any help, I dont visit the JD board here much I usually hang around on the crawler board. I dont work on the JD farm tractors much there's quite a few in my area but they just dont seem to break much so I dont have alot of experience on them.
gatractorman
02-19-2005 15:22:35
 Re: 5300 intermittent tachometer in reply to Gatractorman, 02-17-2005 14:37:28
Thanks for the replies guy's, I dont know if another power wire would work or not but it's already messed up cant hurt to try. Thanks again
leon
02-18-2005 04:37:01
Unless you succeed with something like the earlier suggestion of a jumper wire, I'm guessing you'd be much better off replacing the cluster. Dust and especially moisture getting into these things is a problem, sometimes even with original ones that are supposedly totally sealed. I doubt that you could ever get it sealed up again if you opened it up. Further, I don't think you'd find much servicable in there.
Tim A.
02-17-2005 14:58:08
Could you just run a separate fused power wire to the rpm sensor...or would that not work?
Tim
