4010 Diesel Misfire
SAMMY
02-17-2005 08:38:15
Complete engine overhaul with John Deere parts. Cylinder head reconditioned with valves, guides, seats as needed. Reman nozzles and inj pump. Engine starts and idles perfect. Speed engine to 1600 rpm and it runs good for 15-20 seconds then misfires and smokes excessively. Only 15 minutes run time on engine. Any ideas?????
Gord
02-19-2005 08:33:44
 Re: 4010 Diesel Misfire in reply to SAMMY, 02-17-2005 08:38:15
Make sure that the return line to the fuel tank is not plugged, If it is plugged then the tractor will run poorly. Blow through the line in reverse direction of normal flow and check for particles.
jdemaris
02-17-2005 19:51:24
Many things can cause the problem - but I'd check the timing advance if you're sure it's getting fuel okay. If the advance is not working, it will start fine, idle fine, but tend to break up at higher RPMs. Easy to check if it's a DB injection pump, stick a degree window temporarily on the injection pump, start it up, and check it. If you have the little "pancake" C or CB pump, then I don't know a good way to check it on the tractor without a pulse-timing light.
ET
02-17-2005 09:00:30
It sounds like you are running out of fuel. What condition is the transfer pump in? If you turned the fuel off under the tank, is it all the way back on? Also is there free flow of fuel out the fitting on the bottom of the tank?
