70G powertrol - re/re
StuBC
02-17-2005 07:42:20
I have my powertrol off my 70, to redo the rockshaft oil seals. There is one part of the phase that is giving me trouble. It is the part about removing the piston by applying air pressure. "Force the piston out of cylinder by applying air pressure to the hole W on figure JD 1223" or something like that. That hole is about an inch in diameter. What trick or ideas do you have to seal that 1" hole off to apply air pressure? I do have a compressor with an air wand. Any ideas would be appreciated.
mile0001
02-17-2005 15:08:37
 Re: 70G powertrol - re/re in reply to StuBC, 02-17-2005 07:42:20
I just did this on my 60, but what I did was put a bearing puller in there, as that piston has an edge that the puller can grab on to and then just pull it out. Cause I couldn't figure out how to get air pressure in there either. Although, next time I might try the shop rag or cork trick.
andrew
36BinMN
02-17-2005 11:57:06
More thought... The rubber or cork plug may work. If you can keep it sealed well enough to push the piston out. I wouldn't think it should take a lot of pressure to push it out. BE CAREFUL!! If the piston is stuck or becomes stuck it could fly out of there like a cannon going off. Use little short burst of air to get it out. Maybe it would be best if the unit was not totally sealed ?? . I have never done this operation before. Good Luck and Use your head about it!!!
36BinMN
02-17-2005 10:41:04
Hi, Can you get a plug from a hardware store that will fit the hole? If you can, drill a hole in it that your blow gun can seal-up, and install it back in the hole!! It should do the trick for ya!!
StuBC
02-17-2005 10:53:54
 Re: 70G powertrol - re/re in reply to 36BinMN, 02-17-2005 10:41:04
Good idea, like a rubber plug or cork or something.
36BinMN
02-17-2005 11:45:48
 Re: 70G powertrol - re/re in reply to StuBC, 02-17-2005 10:53:54
Hi again, Actually I was thinking of a threaded plug. Like the one to drain the water or something. that hole you need to plug is pipe thread isn't it?
F-I-T
02-17-2005 11:55:41
 Re: 70G powertrol - re/re in reply to 36BinMN, 02-17-2005 11:45:48
I would just wrap a shop rag around my blow gun, and keep your head clear in case it comes out with a "Whomp!". Try to hold a wood block over the bore end so it has something to bump up against, then you can cushion it with your hand and lead it out.
Frank
StuBC
02-17-2005 12:09:18
 Re: 70G powertrol - re/re in reply to F-I-T, 02-17-2005 11:55:41
I will do what Frank suggests, this isnt his first rodeo I bet.
