70 D
Draf-o-matic
02-17-2005 05:42:39
I have a 70D that I am trying to decide if it is a rebuilder or a parts tractor. The diesel runs well we have had the head checked and the cylinders are ok. The ring gear on the flywheel is bad, I have found a good one. The clutch is completely stuck and will need all new components, the drum has a piece cracked out of it. The pony does not run but has good and equal compression on all holes, it needs the lobe for the points and the complete coil box. All of gears in the trans look good as we turn them. The power troll seems to work right. The sheet metal is good and the power steering works good. Tractor does not have three point. What is this going to be worth when restored. What is it worth in parts? I know a lot about tractors of the other color but little about the the green ones. Thanks
JPatton
02-17-2005 12:16:45
 Re: 70 D in reply to Draf-o-matic, 02-17-2005 05:42:39
Draf-o-matic
I have a 70D that needs restored. I have been thinking that maybe a parts tractor would be the more cost effective way to go. My email is [email protected] if you are interested in selling.
Emerald70D
02-17-2005 06:19:20
Drafomatic...the value of a 70D depends alot on where you are located, style of front end, size and condition of rear tires, if it has live pto, condition of the pony engine and the history of the flywheel. They are relatively expensive to restore and do not command the same market values of a restored JD 720D or a JD 730D.
