1010 won't start
ronson
02-16-2005 19:55:52
Help! My 1010 won"t start. I"m not much of a mechanic but I"m trying to learn. About 3 weeks ago went out to start tractor and all I would get when I turned key was a faint click from solenoid. Took off wiring to clean grease off front of solenoid. Nut on main lug was loose and when I reached up to straighten lug, about a spoonful of "water" came out of solenoid. I removed solenoid. It had "gunk" inside front portion. Cleaned it inside and out. Reinstalled it, turned key and now get (what sounds like to me) a good sounding "pop" every time I turn key but starter won"t spin. Either the solenoid already had a crack in the front plastic part running from lug down side of plastic to edge of plastic or I overtightened nut on lug. Would this affect operation of solenoid? I wouldn"t think so, may let dirt in over time if I don"t superglue it. What could be keeping starter from spinning? What is purpose of "piston" coming from inside engine housing at back of solenoid serve? What should I try next?
Loren NC
02-19-2005 03:36:58
 Re: 1010 won't start in reply to ronson, 02-16-2005 19:55:52
Start with the basics: Is your battery charged? Of course, that would have nothing to do with water in the coil, but otherwise all the symptoms you mentioned would come into play if you have a dead battery.
ronson
02-19-2005 23:15:14
 Re: 1010 won't start in reply to Loren NC, 02-19-2005 03:36:58
Loren, I charged the battery a couple of weeks ago and tester showed it to be charged. I plan on testing it again, may need to charge it again. I may flip the disk in solenoid over next. If that doesn't work, I will either try to bypass solenoid and go straight from battery to starter with a jumper cable or install new solenoid. What do you think? I've never started anything bypassing the solenoid. I'm wondering how the bendix in starter will engage. Does the solenoid cause the bendix to engage via the piston inside the solenoid?
jdemaris
02-17-2005 20:00:40
You can buy a new solenoid cheap, it's almost not worth screwing around with. That being said, you can also buy a "repair kit" for the solenoid which gets you just a new cap and a set of contacts. NAPA and I'm sure many other places sell it - it's the same Delco solenoid most older Chevys cars and trucks use. Now, under the cap is the piston you mentioned with a brass disk attached to it. This disk, when energized, makes contact with two brass lugs attached to the cap. So, you need three parts in good shape to make contact so the starter can turn - the disk, and the two brass lugs. All three parts can be turned over once to get a new surface. You flip the disk over, and you rotate the two brass lugs 180 degrees. When you hear the solenoid "snapping", that's the sound of the disk hitting the lugs - so it's hitting its mark, but contact isn't being made probably because the contacts are hammered.
ronson
02-17-2005 21:03:36
 Re: 1010 won't start in reply to jdemaris, 02-17-2005 20:00:40
I rotated the two lugs 180 degrees but I didn"t flip over disc. Will try that next. If it doesn"t work then, I will install new solenoid. Is there a possibility that the starter is "hung up"? Can I spin the starter some other way to make sure the starter is not "hung up"? Can I start up the tractor by bypassing the solenoid?
lloyd sc
02-20-2005 19:30:21
 Re: 1010 won't start in reply to ronson, 02-17-2005 21:03:36
The solenoid moves the gear into place on the flywheel so that when the starter turns, it turns the engine thus starting the motor. Bypassing may make the starter motor spin but while not under load you can't tell if it is usable.
ronson
02-21-2005 13:13:31
 Re: 1010 won't start in reply to lloyd sc, 02-20-2005 19:30:21
lloyd sc, thanks. what should i try next? would it even be worth my time to spin the starter? if i do try to spin starter, should i disconnect cable from battery to solenoid? or should i just take starter off, disassemble, clean, inspect/replace brushes? it may be just as gunked up on inside as the solenoid was.
lloyd sc
02-21-2005 17:09:38
 Re: 1010 won't start in reply to ronson, 02-21-2005 13:13:31
The quickest would be to take starter & all to parts store & have it bench tested. Solenoids are pretty cheap anyway you look at it. I have a working tractor so I don't worry much about keeping it stock. If you are going to restore it you might think about just having it rebuilt at a shop that does starters & alt etc. Lloyd
