40 T HYDRAULICS
Daniel
02-16-2004 17:55:11
First I want to thank everyone for their help in the past. I received some much needed advice on an electronic ignition problem earlier. I now have that resolved and the tractor is running great. I recently broke up a field with 2-16 moldboard plow.
This question is on the attachment of the 4200 cultivator. I have used this cultivator for a couple of years and the lifting and lowering on the front set is indenpendent from right to left using the separate levers. I have asked this before and was told I must have the cultivator hooked up wrong. I do not. How can I make the right side front cultivator lift simultaneously with the left front? The arm does not move until I lift the rear section. It is a one piece arm on the right not two pieces as on the left. Am I missing something?
Does anyone have any experience with this?
Please let me know. I am happy with how it is working now but am not sure if something broken or what??
Thanks,
Daniel
lc
02-16-2004 18:31:57
 Re: 40 T HYDRAULICS in reply to Daniel, 02-16-2004 17:55:11
I have a 40t, and also the cultivators. Haven't actually used them in about 40 years. Best i remember the right (outside) lever operated the right row and also the back cultivators. THe left lever operated the left front only. This is done by removing the pin that fastens the lift arms together on the left side. Also, the lever under the left side of the seat is rotated to the back position. Hope i have remember somewhat correctly.
Daniel
02-16-2004 20:08:53
 Re: Re: 40 T HYDRAULICS in reply to lc, 02-16-2004 18:31:57
The way you describe it is exactly how it is operating. I was concerned that I did not have it mounted correctly.
Thanks for your help.
Daniel
buickanddeere
02-17-2004 05:17:13
 Re: Re: Re: 40 T HYDRAULICS in reply to Daniel, 02-16-2004 20:08:53
Depends which was the divertor valve(s) are set under the left side of the drivers seat. Your operators manual shows which way is for both rockshafts on one control lever and bolted together. And the other direction so each arm has it's own hydraulic control with the bolt removed. The dual rockshaft allows separate height adjustment depending on soil conditions,slopes, headlands etc.
Wayne in Tn.
02-17-2004 05:53:28
 Re: Re: Re: Re: 40 T HYDRAULICS in reply to buickanddeere , 02-17-2004 05:17:13
Yep! She is working correctly. If you want to lift them at the same time, move the lever under the seat to the forward position and then put a pin through the holes in the Left lift arms, pinning them together. Then you will have it in the DUAL mode. Therefore the term " Dual Touch-O-Matic"
Wayne in Tn. (afterthough
02-17-2004 07:32:40
 Re: Re: Re: Re: Re: 40 T HYDRAULICS in reply to Wayne in Tn., 02-17-2004 05:53:28
I forgot to mention, the manual says after changing to the Dual mode, you should pull the INSIDE control knob all the way in the UP position and secure it there with the wing nut. Then only use the OUTSIDE control knob for operation. Failure to do this can cause damage to the lift.
