41 A carb leaker, Final update
donwisc
02-16-2005 18:59:46
The Old A has been started and run about 6 times and driven around the block without any further leakage out the inlet.
Duane you may have put your finger on the problem with the float not centering on the pin, I may be lucky now but if the problem reoccurs I will look to shim it like you suggested. All that is different is a new seat and needle and bending the float lever down a bit.
Thanks again to Duane Buckeye and Earl for all the feedback
Duane Larson
02-16-2005 20:59:12
 Re: 41 A carb leaker, Final update in reply to donwisc, 02-16-2005 18:59:46
donwisc,
Good to have the problem solved. Sounds like lowering the fuel level may have helped. Hope it continues to behave.
