830 jd cranking engine smoking
ron sharpe
02-16-2005 15:04:37
I want to put valve seals on my cranking engine to stop it from smoking. Has any one else ever done this before?
720Deere
02-16-2005 19:34:50
 Re: 830 jd cranking engine smoking in reply to ron sharpe, 02-16-2005 15:04:37
There are no valve "seals" on a pony motor. You can replace the guides to tighten up the clearances, but chances are worn rings are just as much to blame as the valves. I put new rings and valve guides in my pony last year along with new sleeves. I wanted new pistons but they were $235 each. The new sleeves brought the tolerances back to the comfort zone. After all that, the pony still smokes a little bit at startup but runs very clear after 5 seconds.
In order to install new valve guides you are far enough into the project that you might as well at least hone the cylinders and install new rings. You would be surprised at how much wear the rings may have on an otherwise healthy motor.
Pony motors really are fairly easy to work on. A ring job and valve guides will probably fix your smoke problem, but unless it slobbers oil out the exhaust, I wouldn't dig into the motor to eliminate the smoke.
buickanddeere
02-16-2005 15:30:01
Change the cranking engine oil, often diluted with gasoline when the operator does not use the fuel shut off and proper stopping procedure. Make certain it's firing on all four cylinders. It's possible the oil drain back hole in the cylinder heads is plugged with 45 years of sludge. Even the best rebuilt cranking engine will smoke a wee bit. An engine running not fully warmed up at full power tends to smoke.
ron sharpe
02-16-2005 18:25:48
 Re: 830 jd cranking engine smoking in reply to buickanddeere, 02-16-2005 15:30:01
The engine runs great, i cheked the oil returns and they're open it looks like new under the tappet covers. I always shut the fuel off and let the engine stall then shut off the ignition and the oil is never diluted with gas and it is fireing on all four. I just want to make it better with valve seals, and just wonderd if it has been done before?
buickanddeere
02-16-2005 21:36:52
 Re: 830 jd cranking engine smoking in reply to ron sharpe, 02-16-2005 18:25:48
For the fun of it try a straight weight 30 or 40 oil depending on the temperature. I've got a feeling however you are pulling my leg a little. You seem pretty quick with all the right answers and still real keen on valve seals anyways. Since you have the hood and rockerarm covers off? May as well pull the heads, install guides and maybe valves as 720 pointed out. And measure the bore wear to find out if it's guides,rings or both letting oil past. One has to consider if it runs fine but smokes a bit. Maybe just leaving the thing alone is best. Then again checking the rod clearances, replacing seals, freshing up the clutch,brake and transmisson can't hurt. What does the engine read for compression dry and with a squirt of oil?
Ron Sharpe
02-17-2005 08:15:30
 Re: 830 jd cranking engine smoking in reply to buickanddeere, 02-16-2005 21:36:52
I dont know what the compression is I will borrow some equipment and test it
