B model Radiator Neck
5th Wheel
02-16-2005 08:24:29
My old B is in good shape and the radiator is too with the exception of the top of the neck where the cap screws on. It is rusted and the cap will not tighten. Is there a way to cut off the old and get a new one to weld on???
mitchp
02-16-2005 20:28:14
 Re: B model Radiator Neck in reply to 5th Wheel, 02-16-2005 08:24:29
you'll have to get the area around the neck very hot with a torch, inside and out, and it should twist/pull out. probably have to heat it again putting the new one back in so you can get the metal to expand, don't try to drive it in though, do more damage than you'll want to do
Jason Z in MO
02-16-2005 09:29:23
Those filler necks press into the upper radiator tank casting. You can buy replacement necks from Minkota and K&K...
Can't find the number for Minkota but K&K is at:
http://www.kkantiquetractors.com/products2.asp?id=33
