70 loose flywheel
Donnie
02-16-2004 16:53:44
Does anyone know of a way to tighten the flywheel on a 70? Was taking the starter off for repair and the flywheel moved tried tightening the bolts but no luck. I was thinking of building up the crank by making a few passes with the welder and then grind it back down to a tight fit. What to yall think
Clooney
02-16-2004 17:41:55
 Re: 70 loose flywheel in reply to Donnie, 02-16-2004 16:53:44
Donnie, that is a very difficult repair to weld the crank up then grind all those splines straight & true & at the same time get a tight fit.. It can be done but it a tedious job & is next to impossible without good measuring equipment & good clean welds.. Unless the flywheel & crank spilnes are a good tight fit & have good complete contact at all points it will work loose again in no time.. I would bet your flywheel inside splines are quite worn also so without machining those straight again or replacing the flywheel you will still have problems..
~By far your best bet is to install a Taper-Lock flywheel as those tighten down on most work cranks..
[email protected]
