Buckeye Al and Duane Carb leakage update
donwisc
02-15-2005 18:19:47
Ive gone back to the basics today with a new seat and valve and adjustments, just possibe the float was hanging up on the bowl housing, bent the float arm to get a little more clearance.
The bowl vent theory is interesting but I got the opposite situation, there are no baffles in the hole at all and the passages are all free.
I had a hose running from the drain on about the 5th time of putting the carb on to check the fuel level in the carb and it was up to the split line of the bowl.
After this email I am putting the carb on for the last time tonite with a new valve and confirmed adjustments. I think this may have been a intermittant problem with the old valve and adjustments, I will let you know and thanks for the good replys. You learn something every day
Duane Larson
02-15-2005 20:56:51
 Re: Buckeye Al and Duane Carb leakage update in reply to donwisc, 02-15-2005 18:19:47
donwisc,
The fuel level should be 3/4" below the bowl/body interface. Trust me, it is not at all uncommon to have a new needle and seat leak! On the carburetors I rebuild I always pull a vacuum on the needle and seat, and if it leaks I polish the needle/seat with aluminum oxide polishing compound in the lathe until it holds a vacuum. Aggrevating that this must be done with new stuff, but looking at the new needles shows a plating which is nonuniform and often won't seat.
Did you ever figure out your carb number and if it is brass or not? Also the new floats often have a narrower width at the pivot point and can move around enough to hang on the neck. It is not unusual to have to shim the float arm with washers to properly center it on the neck. Oh for the days of good replacement parts!!
Earl S.
02-16-2005 13:21:41
 Re: Buckeye Al and Duane Carb leakage update in reply to Duane Larson, 02-15-2005 20:56:51
Duane, I am sick of the quality of the metal needles. I have always liked to use them. Over the years I have saved a lot of the old ones I have replaced on rebuild . I have had good luck drilling the old seat a few numbers bigger so that I am on a new area of the needle.Another thing I have noticed when I build a carb I always assemble the bowl assembly plug the btm hole (stem) and hook up my gal test can.I have noticed the alcohol blend gas will crawl right up the sides and drip on the floor if I leave them set for 30-45 min.We only have 1 station that sells straight gas. It will crawl inside the bowl but wont come over the sides and drip.I use 10 % in all my vehicles I believe in the farmer support.I always tell guys to shut the gas off let them run dry.I have a new sediment bowl on my 35 "A" I took the gas line loose and was running a puller carb (I modified) to check it out and I really had to tighten down the shutoff or it would leak. Like you said we have to check everything because of (QUALITY). Earl
Duane Larson
02-16-2005 20:56:17
 Re: Buckeye Al and Duane Carb leakage update in reply to Earl S., 02-16-2005 13:21:41
Hello Earl,
And the suppliers of those needles and seats don't seem to have a problem because they have no complaints on record! I'm not sure what they have done with mine.... . I normally use varsol for my leak testing and it also suffers from capilliary action - but that does show the leaks.
Good to hear your comments on this problem.
Regards,
Duane
Lee B
02-15-2005 19:19:17
Coming in late like this I'm a bit in the dark but I would like to comment anyway. Use of hose to find gas level quite clever, kudos to who ever came up with that one. I'm suspecting that the split level of the bowl is too high but I don't have a carb in my lap at the moment to verify that exactly.
What I can pass on as a general rule of thumb as far as setting float levels not only on our johnny-poppers but for most all carbs is to set the level such that the float itself is level just by eye. In your case, the top and/or bottom surface of the float should be level when you hold it up with a finger simulating a full bowl of fuel. Remarkably this generic rule of thumb has borne out over decades of professional work as well as even more time just tinkering around.
It's best to do this with the fuel turned on so you can see the float level that corresponds to the point where the fuel ceases to flow. You can also then judge by the upward pressure applied to the float with your finger whether or not the fuel inlet valve is too leaky to actually work for you in the first place. Some inlet valves have an additional spring loaded plunger mechanism which often confuse the mechanic working on it as to where/how to set the float level. Set it where the gas stops flowing and you can't get it wrong?
