JD 4010 Gas seems to run rich
corky
02-15-2005 17:59:44
Recently purchased 4010 Gas has a lot of black smoke. It also doesn't respond well to the throttle. If one opens the throttle too fast it may kill the engine. Other times it will over speed the engine. Therefore, it is hard to adjust the throttle to the desired rpm. Are there any external adjustments to the carburator? Or what is your suggestion? I can't tell from the sound if the engine is missing.
Thanks
Mike M
02-16-2005 04:35:37
 Re: JD 4010 Gas seems to run rich in reply to corky, 02-15-2005 17:59:44
Ditto on junking that aluminum MS carb. if that's what you have. I got a 4020 gas put a cast iron Zenith on it I got a good deal on ( it came off of a 3020 )runs great now.The carb .I found has adjustments on the load and idle so it can be fine tuned.
J. Schwiebert
02-15-2005 19:21:05
That is a power jet in the M-S carburetor, if the diaphram is bad or the power jet is stuck they will run rich. You can check it out with some plastic tubing and a vacuum gauge. (Carburetor must be off.)
Hoosier JD
02-15-2005 18:22:46
Corky,
My 4010 ran rich, I rebuilt the carb, replaced plug wires, added electronic ignition, new plugs of several different brands, set timing.....everything helped, but did"t fix the problem. I talked to Mother Deere, they asked if I had a Marvel-Schebler carb,(which I did), they stated that JD automatically replaced these carbs with Zenith carbs when the tractors came back with problems of that sort. I bit the bullet and spent $450 on a new Zenith, best money I"ve spent on the 4010 yet. Starts right up, idles good, and runs almost 2x as long on the same amount of gas, and was easy to adjust. I only use it to ride and to plow snow all up and down my road and who ever lives with riding distance, so it doesn"t get worked too hard. Also put Autolite 388"s in it, a little hotter plug, doesn"t foul out. Good luck, Mike
BMAN
02-15-2005 19:21:53
 Re: JD 4010 Gas seems to run rich in reply to Hoosier JD, 02-15-2005 18:22:46
Dito to Hoosier JD. My 4010 was running rich and nothing really helped until I also bought a Zenith carburetor. It runs so much better now and doesn't foul plugs like it did before. I bought the carburetor from The Company in MT Pleasant Iowa.
Corky
02-15-2005 19:43:23
 Re: JD 4010 Gas seems to run rich in reply to BMAN, 02-15-2005 19:21:53
What is the name of the company in IA and do you know the part number?
BMAN
02-15-2005 20:31:37
 Re: JD 4010 Gas seems to run rich in reply to Corky, 02-15-2005 19:43:23
Call them at 800-634-4885
Gerald J.
02-15-2005 20:04:00
Shoup (www.shoupparts.com) and value built (spelling) both sell Zenith carburetors for 4010 and 4020.
I found a few things outside the carburetor on my gas 4020 that contributed to black smoke.
The top of the Donaldson precleaner was squashed down from being tightened too tight. I popped that back up and reduced the restriction.
The float needle and seat were worn and leaking and so making it run richer.
The choke wire sheath wasn't anchored near the carburetor and so would only open the choke half way.
The air cleaner was dirty. Unless your 4010 has been changed, its an oil bath air cleaner and the cleaning media (steel mesh or steel wool) may need a severe cleaning so it can pass air properly.
In cold weather the intake manifold needs heat, up to 90 when not plowing.
The plug wire were carbon and intermittently open. The plugs were very cold Champions.
The timing was at top dead center instead of advanced 20 degrees.
The point gap was wrong.
After fixing all of those things my 4020 is running lean enough it needs to be choked even for warm starts, but once in a while I flood it.
Studying the JD shop manual, there is a lot to be adjusted in the M-S carburetor and I suspect much of the rich running comes from a split in the vacuum diaphragm but I've not tried to make a M-S run on my 4020. I do know that the change is very popular.
Gerald J.
